Ives2210
- Pensacola, FL
1997 XJ. I used freeze off. I used every penetrating oil I have. I heated it (propane torch). I heated then sprayed water on it (internet search suggestion). The rod in the puller is completley flat now. I've got an IR impact that goes to 550 ft/lbs. I also used assorted variations of F bombs and it still won't come off.
Any suggestions?
...and yes the nut is off.
Any suggestions?
