Strange ticking???
werewoulf3
havelock, nc
Im putting this in the OEM discusion because the motor is stock.....ok it is a 98 with 150k, 4.5 lift, 33" tires
ok when running and idling in gear there is a small tick, when in neutral the tick is more obvious......it sounds like something knocking around, like a spoon in a glass but a softer clank, atleast from in the cabin.......really cant hear it while driving though
any hints other than pulling the diff cover?
Before you get too fussed, make sure it isn't the evaporative purge solenoid They can tick and knock at idle. Unplug the connector to see if it stops.
