Dcoy1283
- Apollo, PA
Ok, so I have been trying to figure this misfire out for a while now, and im just so lost right now. I have a 2000 cherokee XJ with 143K on it and its giving me a p0304, cylinder 4 misfire, and sometimes one about an very small evap leak ( but not lately). Basicly it starts and runs alittle rough ( when cold ) then misses and runs real bad within a mile from where I leave from ( this is when I get the misfire code flashing) then if I shut it off and restart it will run fine. This only happens when the jeep sits for a few hrs, but never when its hot. I changed the plugs ( copper core) coil rail, cam sensor, crank sensor, TPS, the ECM, swapped injectors around, did a compression and fuel pressure test, ran seafoam through it, checked the index of the cam sensor ( was good) and a coolant temp sensor, looked all over for bad wires or loose conections. Still having problems. Please Help, Im lost
