This is a Tomken Machine rear bumper for a 1997-2001 XJ. It has the rear quarter panel protectors, hitch receiver and a tire carrier.
I'm also including with it some frame inserts that slid into your frame bolt up through the hitch mounting locations. This makes the bumper and hitch a VERY strong piece of your XJ - you can tow and pull to your hearts content!
The tire carrier is designed for up to 33" tires but with the frame inserts I've had my 37" on there for a couple trips and it works great. It does hang low though so if you roll bigger than 33" you'd want to raise the mounting point.
Also, I'll throw in a license plate relocating bracket complete with light. (not pictured)
BUT WAIT, IF YOU BUY NOW: I'll also throw in a Warn Receiver Shackle Bracket and 3/4" shackle!!!
If you buy it, I'll help install it and make sure everything fits and works right. Also, I was planning on welding the frame inserts to the bumper for added strength, I'll do that if the new owner likes the idea.
Brand new, you're looking at over $1,000 of good stuff here (not including the frame inserts!). Obviously it's not new, I started to knock the rust off but it still needs some time with a wire-wheel before it's ready to paint. I have cut and folded my rear panels and built a new bumper so I'm done with this.
I'm asking $400.
PM, Text, call:
Aaron
eight-O-one 824 - 6971
PICS:
Without Tire Carrier:
With tire carrier:
Frame inserts:
Here it is with the frame inserts lined up:
I'm asking $400.
PM, Text, call:
Aaron
PICS:
With tire carrier:
Frame inserts:
