Rammin97
- Auburn, CA
I just posted the black jeep on CL. I will take 100$ off Naxja.
Drivetrain is sound, Transfer case shifts perectly, 4.0 HO 6, 161,xxx, new radiator/hoses, Alternator, and TPS. Up-counrtry coils(1 inch taller) and newer shocks up front. Extra Main leaf spring in the rear along with Rancho 5000 shocks.Patched body rot on the roof and topped with a couple coats of bed liner. A/C removed and the windshield is cracked but does not leak. Tires are basically rollers since they came from another jeep so 1 has uneven wear and should be replaced. Other 3 are road worthy. Non-Op with clean title. I even have the 1 day DMV pass so you can drive it home.
http://goldcountry.craigslist.org/cto/3842682696.html
