seth15210
- Sarasota, FL
so i have a 95 xj, i was getting really rough starts so i did the research and replaced the cps. didnt fix it so i replaced the distributor pickup. didnt work either.cleaned the iac valve. after resetting the computer it would run ok for a day or two. i replaced the starter the same time. it was on its way out anyway. i was thinking either the map sensor or the pcm itself or maybe the distributor itself. also around the same time this started the oil pressure sender started reading red lined and beyond, so i replaced the sender seems ok now. im tired of throwing money at this and just need some better ideas. sometimes it bucks so hard it stalls. seems to do it more often if the engine is hot, i read the threads on the newer xj and the fuel pressure problem but i dont think that pertains to the older ones.
