im going to a ford dana 44 in the front and will be running 38s. what is a good steering box to run that can handle the tires and which knuckles do i need to run high steer.
You can do aftermarket knuckles or find a drivers Chevy knuckle, and another Chevy pass side knuckle and have the holes tapped(and drilled?) and the surface machined flat.
Look into a Durango steering box. I would also look into running hydro assist. Make sure to plate your frame, with a kit like the C-rok or JKS one. I like the JKS design becasue it welds to the frame. Use grade 8 bolts, and possibly a box brace like MORE's or Crustys.
