Bump steer will most likely be an issue now. You have lowered the drag link and not it is not parallel to the track bar. A solution here would be to raise the bottom end of the track bar or lower the upper end.
Raising the bottom end would require a new, higher mount on the axle, while lowering the upper end would require a lowering bracket.
It should be raised/lowered an amount equal to the extra drop in the new pitman arm.
Good luck, sounds mean.
Jared
