Cottontail
Three-De Off-Road
- Nashville, TN
Hey y'all...
Prepping my XJ for a front axle swap next weekend. Found a couple "grease boots" that have ripped. Going to post pictures (sorry for the fuzziness...my camera isn't great). Can someone confirm what these are called so I can look up parts and if they are replaceable like a ball joint, or if I have to get a larger piece.
There is a small tear that is inside this red box. I want to consider a ZJ tie rod as soon as a decent one shows up on the PAP yard. Do I run it as is? Do I replace it, and if so, what needs to be replaced...the whole tie rod end?
This is obviously an epic failure. The boot has completely split and came out. I circled the area with the grease fitting that is connected to the bolt that has the arrow towards it where the castle nut tightens down. What do I need to replace here?
