You can also use the '87-'90 model column as well. The wiring is a match . I put one in my friends XJ Tues. night after he lossed his keys and then took an F'n HAMMER to the column. Also, the column uses the same key for the '91-'94 model, '95 is it's own animal. If you take the wheel off, and look at where the little "tab" is for the key switch, and see a hole right below it, that has a countersunk look to it, then you CAN use the early model key switch IF you also ues the lock screw that goes in the hole. Around here the old style key switch is $11, and the Chyrsler style is $40. Do the math, if you ever need to replace just the key switch.
