xjon
- So.Cal. MV
Issue started at a gas station. Filled up with gas and then no start. All lights comes on and starter doesnt turn. Tried a quick jump and still same issue. Checked voltage with a meter and had 12.5 volts at battery. No current going to starter terminals while someone was turning the key. Starter fuse all good. Pulled the starter off the jeep and had it checked in autoparts store. They said the starter is old but still works fine.
Just wanted to check in with you guys before I started unravelling the wiring harness. How do you check if relay is ok? FYI, I pulled out another relay that looked similar (I think it said ABS?) and plugged it into the starter relay spot but no luck. Am I missing another part of the equation that I need to check?
Thanks in advance.
Thanks in advance.
