sqweaking from distributor
TGFH
A new noise started today - I finally tracked it down to the distributor - I think. The distributor is tight and not loose at all - but the noise stops when I push fairly hard on the side of the cap. Pushing on either side will stop the noise. Also I can start the noise when it has stopped by doing the same thing - pushing on the distributor cap. Ideas? I haven't opened it up yet - so I suppose that's the next step.
I had a similar problem in my '96 XJ, except it was the distributor itself squealing. Replaced it and all is well.
My 96 sounds like it's got a birdie under the cap. Runs great...just squeaks.
Sounds like the distributor shaft has worn inside its bushing. The only cure is a new distributor.
They are pricey, is there any way to overhaul them. A rebuild kit or something like that?
did some homework and found them priced from $300+ for a new MSD to $55 exchange for a reman. I'm going the reman. route. Oreillys and Advanced Auto are the cheapest.
Mine does this a couple times a year.
I take it apart, douche it out with WD-40, and voila....it goes away. Ive been doing that for 3+ years.
Rick
