Squeak squeak squeak...
Mikel
Hello,
I have a stock 95 XJ (4.0, 5sp). When I make tight turns to either side, I can hear a squeaking noise (Squeak squeak squeak...) that goes away when I go straight. I don't see anything obvious rubbing, and I just replaced brake rotors/pads/drums/shoes. Any idea what it could be?
Thanks,
Mikel
What size tires/lift are you running, it could be the tires hiting the LCA's, my LTB's are so tall that they flex over and i get a nice thumping, but with street tiers it could be a squeek
Hello,
Applying the brakes does not change anything. Tires are the stock size. I am leaning towards a bad U-joint in the front axle...
Thanks,
Mikel
My 95 does the same thing when im turning. Had it on the lift the other day and turned the wheel and spun the tire and the squeak was coming from the u-joint... my-2cents...
