ParadiseXJ
- Paradise, CA 95969
I'm putting on 3.5" lift leaf springs with angle shims (came all bolted up with the springs). The springs have a large end and a small end. So which end goes in which position?
I know I should just look at the Paradise XJ and install likewise, but I'm not even sure that those springs are installed correctly because it sags so badly that I think they (the old springs) were put on incorrectly. I can use all the pics you got. Thanks.
BTW the front springs I understand, I just don't want to be in there most of the day and do the rear backwards. The shims going the wrong way might pretty much F things up!!!
