hood latch cable, dana 44 u bolts from rough country, carb choke cable, stock xj nut serts for rear bumper, stock pitmann arm, newer front brake lines (stock 88xj rubber)
bezels, and corner yellow lenses and front lower lamp housings, same as pic below
88 cherokee axles with unit bearings, one set solid passenger, one set with outer part of 2 piece passenger axle, 88xj with awf rear drive shaft with slip yoke, Rustys drop pitman arm (new) rough country 4.5 in lift kit sway bar links, rough country 4.5 lift drop spacers for crossmember, front driveshaft 88 xj, front backing plates, stock 88 xj airbox
stock dana 30 cover, like new coolant bottle and lines, regulator motor, e-brake lever, stock uncracked manifold, stock 88 brake booster/reservoir, 86 2.8l fan and 88 4.0L fan (new clutch)
2 sets almost new rotors, xj knuckles, two very new calipers and two pretty new calipers for xj, 4 sets of brake pads all almost new very good shape, barely seen in bottom corner is a wiper regulator motor 88xj
center caps
cowl cover, grey/blue defrost shroud, top radiator core support 88 xj
blue/grey console, black bezel, console insert
fan shroud (new) 88 xj not sure what all years of compatibility
ac condenser
lower dash panel (down by feet) and rear sway bar
wheel well liners
PM me with what you want and an offer, will ship some stuff buy pays shipping
