mikeny59
NAXJA Member #300
- NY and/or Fl.
Everything was going great replacing wheel bearings in 8.25, first axle shaft went in, c-clip no problem, then...
Other side axle popped one spider gear into drain pan, now both are out, at times can get them in at same time, but unaligned w/center pin holes.
I REALLY need advice asap, going back to finagle some more, will check back soon.
Thanks :angel:
Thanks :angel:
