Just needs replaced, they burn up from lack of lube, the factory one has no grease zerk. The one I posted #607 has a zerk installed and comes with a new ball and spring kit or just replace the ball and spring kit #617, All precision.
This might be a stupid question but how do the zerks in the pics above work I couldn't get a grease gun on them. Is there a special gun for that style zerk? I'm only familiar with the nipple looking type. And with the Centering ball posted above.... Does it come with the rubber boot thing? I checked rock auto way cheaper than summit. Thanks also where's the best place to buy the spicer u joints. Are they all the same in the front shafts. I assume 1310.
I also just found precision 617. What's the difference between the 2? Rock automdoesnt show more than just a lousy pic for info on them. Are there any good write ups for changing these parts? I've never messed with a cv shaft before.
607 includes a new yoke with a zerk installed so you can keep I greased. 617 is just a ball and spring rebuild kit. It takes a needle style end, you can also grease regular zerks with it you just have to hold it in place. I got everything from rockauto.
