finally got my axles regeared. i'm running 4.56 and 32s. when i'm going 70 my speedometer says 90. is that normal? do i need a different speedo gear? or will 33s make it back to normal
d00d, learn to use the search. If you had searched, you might have found this chart on Go-Jeeps site, which then would have told you not only which gear you need, but the part number as well.
Thanks, and God Bless.
