sprngfldxj
- Springfield, Colorado
I have noticed that I am getting a sound out of the motor that sounds like nocking at start up and continuing for a while even after warm up. I have also noticed that that oil pressure is high and then backs down after it is warmed up, with the exception of a few times. I checked the motor as it ran both cold and hot with a stethescope, and have not found anything that seems bad in the head or the block. Do i need to be worried?
I do not have any smoke burning, and I have not noticed any oil in the coolant.
Are the valves adjustable or hydraulic on the 92 XJ?
What should i look for or is this normal?
