- MilkyWay Galaxy
About 10 years ago I checked the compression on my 87 Wagoneer - Renix and had about 130 to 140 psi on all but #1 and #2 cyls. Not sure how low they were, but they were about 5 and 10 lbs over factory minimum spec and all cyls were close enough to each other to be balanced. But I have fixed may issues since then and put about 60,000 more miles on the beast. Been running 20W50 all that time.
#1 and #2 have always had some oil fouling of plugs #1 and #2 over time while the other four plugs look new after 30,000 miles and up. I replaced the valve stem seals about 3000 miles ago on #1 and # 2 and got an improvement in the oil fouling issuing which had gotten way too bad at 285,000 miles. Had to clean the plugs every 250 miles at the worst point. I plan to run a wet compression test soon, but I was already planning to pull the head to get new valve guides and try to get another good 2-3 years out of her with just new valve guides. It is not a going to see a lot of miles. But my MPGs have dropped and I am wondering if it is time to do a complete rebuild or swap. The jeep has always been gut less with the low compression, compared to our 89 Cherokee.
So my question is this. I have no coolant or oil problems. Only oil problem is a recent increase in oil usage. Now using about 1 quart in 300 miles I think. No oil leaks, zero. Most of that could be the leaking valve seals and bad valve stem guides, as the oil usage the last 10 years with 20W50 was not bad. Maybe a quart in 1500 miles.
If I get low compression on my pending compression test on #1 and or #2, could the valve guide seals be so bad as to affect the compression test results? What results would say swap the engine and forget about the head job? Time is a constraint right now, so I am hoping to get a away with a head job for now. The engine does run smooth as glass until the #1 plugs get so fouled as to miss (takes 300 to 1000 miles, I am testing hotter plugs right now/next).
Hotter plugs, which by the way brings up topic 2.
Which plugs would you use to step up the heat range one step for #1 and #2 to burn off the oil and keep the plug cleaner longer?
