SOMEBODY PLS HELP ME W MY 96 XJ
markusamongus
Ok so I have a 96 xj 4.0 sport 2wd 4 door
The jeep runs incredibly strong and has 205k on it. It started the infamous having to turn it over 3 to 4x to start and remained that way for about 3 weeks. I had driven it about 40 miles to go visit a friend - stayed about 1hr - go to leave and it will not start...cranks but no start. Figured it was the cps so changed it w a new oem one I had stashed away. Still nothing. Began trying to diagnose - I have spark and all sensors tested correctly on the ohm meter. All fuses good. So I started looking at fuel issues - when I turn key to the on position- the fuel pump relay never comes on and I have 0 pressure at the schrader valve. However when I try to actually crank it I have 45lbs of fuel pressure at Schrader valve. I'm confused and need to get the ole XJ going again. Any suggestions?? Thanks
So you have no fuel pressure when the key is on (not start)? Then turn the key to Start and you have 45psi?
I don't have pressure until I actually try to crank the jeep - with key in the "on" position, even after cycling 3 or 4x to on and waiting I have no pressure until I actually try to crank
