- Terra Firma
... should not be allowed to own a Jeep.
In fact, SOME morons should not be allowed to even touch a Jeep.
Needless to say, I am not a happy camper this evening. As some of you know, the '88 XJ I've been refurbishing for a friend out west had a non-functioning fuel gauge. After eliminating other possibilities and examining the forensic evidence that suggested the previous owner had dropped either the tank or the fuel pump (or both), this evening I finally bit the bullet and dropped the tank to examine the sending unit.
Sure enough, I found a wire disconnected -- inside the tank. "Great," I think, "for once an easy fix." Plug the connector back on the terminal, tests good with multitester, replace module in tank and start to reinstall tank in vehicle.
And as I reach over to put the nut on the passenger side tank hanger, I feel something wet. Oh, oh. Sure enough, the reason the moron had the tank down is that he had punched a hole in it and tried to epoxy it. Screwed up the sending unit, cut the wires when there was a factory connector a foot away that he could have unplugged ... and didn't get the leak fixed.
I am not a happy camper.
