^^Again, I agree^^
The brake system on this Heep needs be taken apart and checked for all of the things mentioned here. If the back brakes have been recently worked on, it is possible that the leading shoe was placed in the trailing position. Just asking here... Would not this condition lead to poorer stopping? Isn't the leading shoe smaller than the trailing shoe?
So, I am inclined to suspect contamination in the drum. If it is leaking gear oil that badly, she should be able to see it on the tyre sidewall. If it is brake fluid, the reservoir should be low.
At any rate, the Heep is unsafe to drive in the described condition.
The discs on the back on my Heep are from Currie and I believe they are Exploder in design. Biggest issue in the installation were the parking brake cables. That was solved by using a set of Lokar cut-to-fit cables purchased from Speedway Motors. I recommend these to anyone seeking to retrofit disc on the back. Makes life simple.
Yes, I am a Hot Rodder as well... Explains the Supercharger doesn't it?
Some one correct me if I am wrong here...
Drum brakes operate by the leading shoe causing the entire assembly to rotate presenting the trailing shoe to the drum. As the pedal is pressed, greater force is applied (yes, obviously, but some folk do not have the knowledge...) by simple hydraulic action plus the force of the assembly being rotated.
In the past, I have seen assemblies so caked with junk that they never returned to the neutral position. The symptom there was dragging/touchy brakes.
If this Heep's brakes are contaminated, we could be seeing a similar happening here.
