rang-a-stang
- Camarillo CA / Boise ID
Hey all, first post here. I usually live over on the full size jeep forum (IFSJA.org).
I just rebuilt my 2000 AW4 and am adding 4WD (swapped the output shaft and tail housing). I ordered a 4WD case adapter from a wrecking yard. It came with an earlier AW4 output speed sensor installed (the long narrow one, 2PPS). My Cherk is a 2000 with the shorter 4PPS output speed sensor. The 4PPS pickup is ~15mm but the hole in my adapter is about .45". Can/should I just use a 19/32" bit and drill the hole out or do I need a whole other adapter?
(also easy bonus question, should I toss my 2WD output shaft and adapter in the trash or are they useful for someone?)
