ok gettin goodies to get the 95 goin again, makin a good sized order through summit, is everything im getting good? is any of it bad? anything i missed? i hope the motor will start, it hasnt run since nov of 07
Oilpan Gasket
http://www.summitracing.com/parts/FEL-OS34308R/
Valve Cover Gasket
http://www.summitracing.com/parts/FEL-VS50022C-1/
Rear Main
http://www.summitracing.com/parts/FEL-BS40612/
Oil Pump
http://www.summitracing.com/parts/DCC-4529241/
Spark Plugs
http://www.summitracing.com/parts/CPN-412/
Cap Rotor Wires
http://www.summitracing.com/parts/SUM-867625CR/
i know the oil pump is fancy high volume, but those who wheel with me know my engines see alot of abuse and rev limiter so i figured it to be a good thing
a couple thing ill be getting that aint engine related but i figured to get em while buyin other stuff
Lug Nuts
http://www.summitracing.com/parts/SUM-7540163/
Hood Pins
http://www.summitracing.com/parts/FMS-M-16700-A/
Paint For Beadlock Rings
http://www.summitracing.com/parts/SHW-MS500/
Few Things ill be gettin later this month
Brown Dog Block Brackets and Poly mounts
Poly Trans Mounts
Oilpan Gasket
Valve Cover Gasket
Rear Main
Oil Pump
Spark Plugs
Cap Rotor Wires
Lug Nuts
Hood Pins
Poly Trans Mounts
