Shop definitions you need to know.
cf_collins
Antioch, TN
I found this at the Trail Krawlers 4x4 website.
:laugh2:
http://trailkrawlers4x4.org/tkbbs/viewtopic.php?f=1&t=11341#p89373
by ibscrmbln » Fri Nov 27, 2009 11:04 am
This was sent to me by a friend?? of mine. . . . I don't know what made him think of me.
I understand many of you are familiar with the uses for all the tools in the box, but I thought an explanation might be helpful to others.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, shirt!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
They are used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race...
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name
implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SOB TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a botch" at the top of your lungs. It is also, most often, the next tool that you will need.
83 CJ8, 4.0 HO/AW4, WMS hybrid 9" f&r, 6:50 gears, 37" MTRs, etc.
82 CJ8 future restoration project
61 FC170 future project
ibscrmbln Trail Krawler Posts: 94 Joined: Wed Jan 07, 2004 12:45 pm Location: Topeka
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit,...
...,except for the "dead blow" hammer, which is primarily used to crush you thumb.
yes. happened to me a few days ago because i was too lazy to grab the rest of the handle extension. bottle jack to the rescue
Lets add more definitions.
JACK STAND:
The metal objects that are in the corner collecting years of dust while you bench press your XJ that just slide off the floor jack.
DIGITAL MULTI METER:
Over price toy that you will never use.
Unless you own a RENIX then youll be using it all the time...
Compression fitting:
Usually causes leaks when youre too lazy to replace the 3' piece of brake line you snapped the end off of while changing a wheel cylinder.
Ratchet:
Something that slips off the bolt while youre under your vehicle at an odd angle, Hitting you in the face and breaking your tooth.
(never happened to me, but Ive heard of it)
Breaker bar:
Something you use on stuck bolts, usually producing too much torque and breaking the stud. Turning a simple job into an all day/all week adventure!
Brake line bender: a tool used to trap flare nuts at the wrong end of the line so that you get more practice cutting and flaring.
:soapbox:
BFH: a big freaking hammer that is usually too big for the task at hand resulting in glancing blows that land right onto nearby body parts (both vehicular and human)
Pitman Arm Puller: a tool that attempts to remove a pitman arm but then results in the pullers jaws slipping off the part or the jaws shattering. sucess rates for this tool range from .02-.04%
Oh hell, the only hammers that I haven't done that with has been rubber mallets (usually find the part of my hand behind the thumb) and some of the larger sledges.........came close to finding at least one of my feet with those on more than one occasion...............
