drknyt
- Cedar City, UT
so i just turned my MJ D44 into a XJ D44 and i used ruff stuff perches and shock mounts, well the lower (ruff stuff) shock mounts are too high on the axle so sitting normal the shocks are almost all the way compressed, if not all the way, i don't want to move the mounts down because i always hang up on them on rocks and love that their out of the way, so i was thinking i could make a upper mount on the inside of the jeep, only thing is this whole cage thing that they're bolted to, also the passenger side shock upper mount is like right under the back half of the rear seat because that shock is mounted infront of the axle, so i dont know what to do, i could maybe move the passenger side lower shock mount to behind the axle but i know that having a shock on either side helps a little with axle wrap, so i need some help/opinions, i tried searching but found nothing that helped with my situation, here are a couple pics, anything help is great!
