the shafts can be stronger but not necessarily bigger. What year is your D30 and is it ABS or not?
From 95 to 01 the ujoints are bigger (297) and IIRC all ABS shafts have the larger joint. You can replace the shaft with the smaller (260) joint with the shaft with the larger joint as a direct swap unless you have a disconnect axle. If that is the case then you have a few more mods before it will swap.
It is usually easier to answer questions when you give as much info about your rig as possible and what exactly you want to try.
