Here's the setup:
1996 Cherokee Country
2WD - AW4
4.0L
Symptoms:
BTW: Where is the transmission connector in the engine compartment? A pic would be nice.
2WD - AW4
4.0L
Symptoms:
- Idle: 1000 rpm
- Throttle position sensor range: 0.84 - 3.89 {5.01v input v+}
- Shift issues: Have to manual shift aw4 to drive
- Battery Voltage at TCU connector
- No resistance on shift solenoids 1 & 2
- spec {11 ohm} on the TC lockup solenoid
- Adjusted Throttle body cable
- Unplugged TCU and shifted manually - no problems
- NSS Cleaned, sanded, and lubricated - reverse lights work
- 1996 No inline fuse for TCU but i confirm V+ and Gnd at connector
- Electric Cooling fan turns on and stays on within 1 minute of starting the truck.
