92 XJ/ 4.0 AX15/ dana 30 chry 8.25/ 3.5" short arm lift/ 33s/ OTK steering...
I am looking for some advice about setting an adj trac bar. I have centered the axle measuring equal distances between a spot on top of the tire and the bump stop tube. When I do this I feel I am preloading the trac bar too much since it takes someone to turn the wheel inside the jeep to get the hole to line up with the trac bar bracket. I am using RE HD bracket and double shear trac bar.
When I hit a bit of a bump going about 55mph all hell brakes loose and death wobble feels like it is going to shake the lug nuts off. Do you guys think that all of that preload is unloading when I hit a bump?
Should I try to find an axle position and adjust the trac bar so that there is zero preload on the bar? Also I have realized my rear axle on leaf springs is not centered either :shocked:
TIA Guys
Nick
