heyhar
- PA (near Poconos)
My '92 is squealing like a stuck pig. When I was putting it back together last summer after I bent the front end, I had to install a new belt. I got the cheap one from Advance, and it chirped pretty good. So I went back and got the expensive one. It was quiet for a while, but is now loud. No amount of tension seems to cure it. I noticed that the 'v-grooves' are a series of ribs, almost like tread blocks on a tire, that are about a quarter inch long, with about an eighth inch space, not a continuous rib like an OEM belt. I'm wondering if this is causing a lack of traction, and the squeal. Does anyone have a sure fire favorite brand or model that they could recommend? I'm looking at NAPA's website, and it's hard to tell if I should choose one merely by a picture. I just got a NAPA 'Krik-it', and this would be a good chance to use it......Thanks
