Ed Wulfe+,
Here's my thought -- you have an automatic transmission...
While cruising at 2K to 2.5K rpm you'd be rolling comfortably locked in 4th gear in the AW4... the key word is "locked" as in with the torque converter locked.
With 31's (and no regear), you're throttle pedal requires some pressure to maintain that RPM (as comfortable cruising)
A slight MAP or TPS change will cause your torque converter to unlock... the added slip in that system accounts for the RPM increase that you're seeing ...
... Y'wanna prove it?
Drive comfortably cruising at/near that RPM range and watch your tach as you gently apply the brake pedal with your left foot (you should only need enough brake to light the lights, not so much as to slow) while maintaining speed with your throttle-foot...
... If you were "comfortably cruising" with the TC locked, the slight aplpication of brake should've unlocked the converter and you'll see the "slip" as increased engine RPM for the speed you're travelling...
(In the unlikely event that you have a manual tranny, and your engine speed increases for a given road-speed, suspect clutch slippage)
