4x4JeePmaNthINg
- Colorado
hey all,
I drove to work today and was sitting parked after a 30 min drive. right before i was going to get out of the jeep i heard the engine sputter, rpm tac dove a little and idled like this for a while 650-1000rpm. It got a little worse as i was studying it and when throttle was applied it really sounded like crap. I shut the car off and popped the hood for a visual witch showed nothing obvious. I turned the jeep back on and it really sounded much worse (up idle and fall... but not slow. not stalling but horrible idle. i offed it and went to work.
At break i push every electrical and vacuum connection in, that i could see, grounds look good. turned it on drove a lap and it seemed to run fine plus it got me home with no issue.
today was the first time this has ever happened
Fairly new: cap & rotor, plugs, wires, Fuel pump, battery, alt, cps MOPAR .
ignition coil probably going to replace for good measure (only because its cheap and ive seen its a possible culprit). IAC is stock but im not convinced its a culprit after driving home. Im leaning coil or vacuum.
what do you all think? 99xj auto 185,300
