roof racks gutter brackets, any thoughts?
ryurabbit
NAXJA Member #611
Yucaipa,CA
I am fabbing a roof rack out of 1' inch square tube .060 thick and am looking for attachment points at the roof rack gutters. Since I am new to the XJ world and have pretty good fab skill, I was hoping I could tap this resource for some pics of brackets that I could easily fab. Any help would be great! TIA!
I built a rack last year out of 3/4" OD tubing and researched all my options to mount to the gutters in a clean, strong and simple fashion. I cut and bent 2" x 1/4" flat iron at about 6" long with a 30 degree bend in the centre. Then I fabbed a bolt tab from 1" x 1/4" about 1 1/4" long, drilled a hole for the bolt to go through, and welded them to the 2". I then took some 16 G sheet steel and cut into a small triangle, then bent the bottom 1/2" to a 90 degree to tuck under the gutter. I cut the heads off four 5/16" x 3" bolts and welded them to the 16 G tabs. The bolts and tabs go up through the 1" x 1/4" tab with a nut and washer on top. It has worked great so far without any rattles and has never come loose. I also stuck some adhesive backed foam tape along the bottom edge of the 2" x 1/4" so it would stick and not scratch. I can take a few picks and post them if you want. Let me know and hope I could help, good luck.
I was just going to order some from kargomaster roof racks and adapt my rack to them, but a friend told me that my rack might be to heavy for there brackets. Hey ROCKY, I would like those pics if its not to much trouble. Thanx for the 411 guys!:bunny: :cheers:
I run (ran) the KM gutter mounts and don;t recommend them for strength vs. trees...bent the sh$t out of them once, broke 2 of them in half at the bend. KM did send me replacements that were re-designed as of last year but I bent those too. I'm gonna make my own and be sure they can take a hit,.
P
I also ran the Kargo master gutter mounts but had to reinforce them by welding gussets in the back.
They can handle a good 400lb of gear no problem but if you start using your roof rack like a skid plate they start to bend :D
Thanx
Well I appreciate all your help and I will post some pics after I am finished. Once again thanx to all and thanx for the pics!!!
:bunny: :bunny: :cheers:
