POS 95' XJ Sport 4.0 - Driveway mechanic.
I'm doing a bunch of repairs this weekend (Flexplate, Valve Cover gasket, Oil-pan Gasket, Rear Main Seal).
Everything is apart but I've run into some concerning problems with the RMS.
The bottom half of the RMS is baked into the bearing cap and I can't get it out. Any suggestions for what to use to remove the old seal?
Then to make things worse, I started off by grabbing my Snap-On pick set, which was a big mistake as I slipped and now I've scratched bearing cap insert.
Click for full size
Click for full size
I'm guessing it's not safe to reinstall with the scratch, what do you think? If it's garbage now then is that something I would need a machine shop to replace or can I DIY that?
Finally, with as badly as the bottom half is baked in I'm thinking it's not even worth attempting to get the top half out. If that is baked in there like the bottom half then there is no way I'll be able to punch it out. I'm afraid attempting to get it out will just make the leak 10x worse.
What would you do?
Click for full size
Click for full size
What would you do?
