Limited89XJ
- Wyoming
My heep had been running around 230-240 degrees. I replaced the fan clutch and found out that it didn't help. So I ordered a new radiator from a local shop (which is alot thicker then the stock one). I install it and it burp the system (backing up on ramps, unscrewed temp sensor, filled until coolant came out of temp sensor port) this is the correct way? And now it is running around 260 degrees constantly. I have no fan shroud, electric fan is kicking on around 215-220 degrees. Thermostat stuck? What else can be done? I am at my wits end here.
Thanks in advance
Thanks in advance
