Rims and backspacing
ARB-XJ
How do i figure out how much backspacing i am going to need? I'm going to to running front & rear 44's both with disks, rear is going to have wheel spacers.
Full-width 44 / TJ 44s...? How wide are they? How willing are you to cut your sheetmetal to open up the wheelwells? How much lift (I assume you're talking about the 6.5" :eek: on 33s in your sig?) There's plenty of variables, and the more you modify your own Jeep, the more difficult it is to answer your particular question. On mine, I knew that 4" BS on a 15x7 worked, but that's because I'd seen what similar setups did and where they rubbed if they differed slightly.
What tire height/width are you going to be running, and what width rim?
Jim www.yuccaman.com/jeep
front is 65" rear is 61" hence the spacers in the rear....tires will be 35x12.50...rims are unknown as of yet. Fenders are already cut and folded.
