- NC Sandhills
We're in the midst of modernizing a 26 year old house, 2100 sq ft approx, the main room downstairs has a cathedral ceiling, and a ceiling fan to push or pull as need be
It has no central AC, but does have ducts for forced hot air (giant #2 oil/woodstove in the basement that takes 4' x 10" dia logs) There are three (2'x2' apprx) intake ducts and a bunch of floor outlets... In other words, the place is plumbed for moving air.
We're in the market for an electric "heat pump" heat + AC unit. Not a 'gas pack'... LPG price is through the roof here. I know we'll have to reroute the intake ducts to hook up to the air handler (I guess to an exterior wall in the basement.) The house is poorly insulated at present, but will have new windows and fresh R19 'glass batts stuffed up in the floor joists before winter, but after snake season.
What I'd like a stab at is how many tons in a HVAC unit should we be looking at, and is that a function of the compressor, air handler(fan) or both?
Maybe this belongs on "Other Tech?" If so, use the 'report post' button & I'll get it moved.
TIA
TIA
