Fringeless
- Roswell, NM
While installing my ebay 200 amp alternator, I found out that my fan bearing was shot. I found a youtube vid of a guy who details the replacement. https://www.youtube.com/watch?v=6SQnw1lqYjs
I ordered the bearing mentioned in the the vid for 14 bucks. When I received it, I noticed that it had a hole in it. I figured what the hell, I could install a zerk fitting right over the hole.
How convenient, the parts manufacturer decided to bore out a cornholio. Perfect for regreasing my fan bearing.
So, I took my calipers and measured from the front of the race to the hole, then I added .100" to that measurement (difference of where bearing stops and front casting). I then scribed this measurement and tapped out a hole for a zerk fitting. Note. Do this on the top left side only (between the 10 and 12 oclock gussets), the right side will not provide enough clearance for getting a drill or tap perpendicular to the hub, unless you have a long-ass drill bit and long-ass tap. (note I used a small 12-point socket instead of tap driver- clearance issues)
Finished product, ready for some good moly grease. Whats up?
Steve-O
iratefla
Steve-O
