Fred85
- Orange, VA
Surprisingly nothing to be found on this topic, at least on a later model. Anyway, for whatever reason my pinion yoke has become stretched between the "tabs" for the u-joint and needs to be replaced.
I understand I can simply mark the pinion nut in relation to the threaded shaft, replace the yoke, and re-install the nut back to the marked position. Anything else to be mindful of?
Should I use a new nut? Loctite? Should I replace the pinion seal? I want to make sure this is done right... (this is a 2001, btw)
