Qban
- Long Beach, Ca
I replaced the 242j tcase in my 98 XJ with a supposedly "rebuilt" one from craigslist. I got everything on and then went for a test drive, however it was short lived as my rear tires (both of them) would just drag, it would go for a few feet then bind up, BTW, I was driving in a straight line. I was able to get back to 2wd and drive for a little but, but when I got it into 4wd again the rear wheels would just drag yet again.
The tcase had been sitting in the guys garage for a while with no fluid in it. So I think the difficulty in shifting could be caused by fluid not being completely circulated yet
So I put it up on 4 jack stands, 2 on each axle with the tires in the air. I put a line of tape on the top of each tire.
In 4 part time the front tires rotate faster than the back 2 tires.
Is it safe to assume that both front and back should rotate at the same speed in this configuration (being on jack stands and in 4 part time)???
I'm wondering if the nv242j in the xjs ever had different ratios for front and back?
Any help would be really appreciated, I think I'm a bit screwed at the moment =)
