I've got a 93 auto and had to replace the leaky HCV...not sure if I need to do any burping since a little bit of coolant came out while I was swapping in the new HCV and hoses were off...
Turn the heat on so coolant flows through the valve and into the heater core, then drive it around. The system will burp itself but you need to keep the heat open to get the air out of the core.
