javashack
- Atlanta, GA
96, 5-spd
OK. I replaced the clutch and tightened everything back up - lowered it off the stands, and went to take it for a test spin. NO start. Getting fuel to the rail, checked the cap & rotor - OK. It turns over but it never sounds like it wants to run. I even tried to bump start it - no go.
I have always been able to start it in gear so I don't think there's sensor to look at.
Battery is OK - good speed when cranking
What should I look at first? Solenoid? injectors? ground? HELP
