BeenJaminJames
- Alabama
'88 MJ RENIX 4.0 AW4 NP231
I'm just gonna start of by saying I've cleaned the grounds and the C101 connector on the firewall, took care of that a few months ago when I first started driving the truck.
The other day it just died on me all at once, no warning, no stumbling or studdering, just shut down and as best I could tell at the time was out of gas, no fuel at all in the rail. Simple enough, I pour 10 gallons in and it fires right up... for about 15 seconds all is well, then it dies. Crank it again and the same thing, springs to life with no hesitation and runs perfect for about 10-15 seconds. Crank it and touch the throttle at all and it dies immediately. Since then I've triple checked everything I can think of, can't figure it out. No fuel pressure gauge available, but judging by how it squirts out when i push the valve in the test port, I'm convinced that's not an issue. Now if i crank it and jump out quick enough with a can of starting fluid, I can keep it running as long as i want, so it's definitely a fuel problem.
I should probably mention that about a week prior, I sprung a power steering leak near the exhaust and set myself a nice little engine fire. Picked up an engine harness and 6 injectors off a neighbor that was parting one out, crossed my fingers and prayed the map sensor was still ok, and got it back on the road for a few hundred miles before it abruptly decided to die on me. Didn't notice anything strange at all during this time after the fire other than awful oil leaks, so I'm not sure if my current issue is related or not, but definitely worth mentioning.
Now when I unplug the map sensor, truck won't start at all, and key on engine off the sensor tests good. Engine won't idle long enough to test it running. That was the only sensor I had a question about, due to it's proximity to the fire. TPS is brand new and tests fine. I wasn't able to test the knock, CTS or MAT sensors before it got dark, but I get no change when i unplug the CTS and knock sensor, with the MAT unplugged it won't start at all. The wiring harness leading to the knock sensor connector has a third non-insulated wire with nothing at the end. Wasn't going to tear apart the harness to find out where it went, but i did try grounding it and saw no difference. Not really sure what else to look for, but in the morning I plan to crawl under and test the CTS for good measure. Other than that, or a bad ECU, I'm stumped. Any ideas? I know I have to be missing something, especially since I'm still new to these jeeps. This is my first electronic vehicle that's not OBD2, and it's giving me fits! :helpme:
