Sorry RaptorXJ, but 39 psi is only correct when the fuel pressure regulator is disconnected for RENIX.
Should be 31 psi at idle.
Then disconnect the vacuum line leading to the fuel pressure regulator and the pressure should jump to 39 psi. Be sure that the vacuum line leading to the fuel pressure regulator is pulling good vacuum and is not wet with fuel, which can indicate a ruptured fuel pressure regulator.
