Well I finally pulled my factory brass tow package radiator and had it rodded and boiled and painted, it has never been out since I owned it for 12 years and I knew the last owners and serviced it since new....... 1990 XJ Laredo
It was 35% plugged..... Jeep running a little warmer then normal.... it was due.......
I never converted to open system with newer radiator off 91 up as the brass replacements are very expensive, I just never liked plastic tanked radiators.... they tend to just split with no warning in my experinces.....
I decided to convert my closed system to open system and get rid of the troublesome expansion bottle I have replaced with OE ones many times and I hate the clutter....... Since I got rid of the crappy Bendix ABS which was giving me probs again, I could ditch the 20 pound Shelf for the ABS pump and expansion bottle.....
I installed my fresh cleaned OE HD closed system radiator, Durango 4.7 filler neck and 15 psi cap in upper hose, 95 heater hoses, trimmed Renix heater control valve to work with 95 heater hoses, ditched Renix expansion bottle and shelf, installed 91 windshield washer bottle and wired and plumbed in place of Renix expansion bottle shelf, installed 91 coolant bottle and 91 PDC bracket to mount bottle, flipped, trimmed and modded Renix relay bank and diagnostic connector bracket and attached to 91 naked PDC /coolant bottle bracket, relocated and mounted Renix ignition coil and module next to brake master cylinder where the 90 windshield washer bottle used to be and did not fit to well after booster/master upgrade,had to extend a/c compressor harness, ignition coil/module harness, washer bottle harness and hoses and a long coil wire off a small block chevy HEI wire set, number 2# cylinder wire....... Also replaced OEM battery cables, they where goo from heat and age..... Already did the battery cable upgrade from alternator and added chassis grounds years ago, those where good..........
I am happy using the stock 91 up coolant overflow, never found a good overflow set up for the Renix closed to open cooling conversions I liked.....
I also like the 91 windshield washer bottle and location, the 90 bottle was just to crammed against the ZJ brake booster, less clutter on that side now.......
Another plus is the coil/ignition module is out of the harsh enviroment where its located stock Renix, its higher up and more protected....... I dont mind the long coil wire now, it seems to be just as long as Dodge 5.2/5.9 coil wires...... runs the same. its bolted right to the fender well seam, very solid mounting.... I was going to mod the stock coil bracket, but I think this works better and is alot easier.......
Next project is install a good factory exhaust manifold I have been saving with no cracks, exhaust wrap it, noticed my utmost rear exhaust stud on head is gone also...my manifold is cracked pretty good......
New factory style motormounts as my poly insert motor mounts I installed years ago are sagging......Just need to get caught up on all the stuff that needs attention I have been putting off, then i can do some mods on my list.....
