tayman
- Niceville, FL
1990 Renix XJ. stock cooling system. (the closed one)
This issue has just popped up fairly recently. It cools fine while moving, and "okay" if I throttle up (I have a hand throttle, I can keep my idle raised).
What's the likeliest cause here? Water pump, or clogged system?
Water pump HAS been replaced in the last couple years. radiator was flushed recently.
