bradleyheathhays
- Lexington, KY
I've been told to completely remove my heater control valve. Never having dealt with this before I'm assuming this is it...
I guess all that's involved is just to remove this valve and re-connect the remaining hoses. Not sure exactly how those connections would go though. Hoses A & B both go to the heater box and hoses 1 & 2 both go to the motor. Here's where the top hose #1 goes...
If I knew what direction the water flowed in that last pic (to or away from the water pump) and which way the water should flow through the heater box that would be enough info to know how to hook the hoses up. I'm guessing the flow through the heater box is 'IN' through the bottom inlet and 'OUT' through the top outlet (in order to let air bubbles escape).
So am I getting this all about right? In what combination should these hoses be reconnected?
