removing studs from X-case
KarmirXJ
how do i remove the studs from the transfer case. I got a clocking ring and I need to remove the treaded studs so i can bolt up the clocking ring in its place... FYI its a D300. but I dont think it matters
BTW: do local auto stores carry new studs?
take the nuts that came off the studs. thread two of them onto one stud. put a wrench on the inner most nut and back it onto the outer nut. you may need another wrench to tighten them together.basically, once you spin them together, you can back the stud out by trying to "loosen" the inner nut.
make sense?
