klennop
- Appleton, WI
So I want to replace my factory fogs with aftermarket ones because mine are junk. I know that there are 2 torx bolts that hold them in place. Well I tried removing one of them the other day and that sucker is on there so tight that it actually almost stripped my torx socket along with the torx bolt. The socket just started moving inside the bolt without the bolt moving so I stopped right away because I didn't want to totally strip the thing. So I am wondering what my options are to get this bolt out if I do end up stripping it out. I can't fit a sawsall in there to hack it off without damaging the plastic around it. Could I just drill into it, if so any bit/size suggestions? I didn't know what heating the torx bolt up would do, if it would just strip out since it would be hot so I didn't try it.
Thanks for any help or suggestions!
